Training
Weezbo
Weezbo Member Posts: 6,231
you are smart money ahead looking into Tim's offer. i think an UGLY'S is an important book in any inspiring electrical /hydronic career.
  • Jason Quinn
    Jason Quinn Member Posts: 96
    Advice from the Pro's
    I am a plumber learning hydronics. I have basic hydronic installation experience, yet most of my installs do not involve wiring or in depth controls. I am currently involved in the RPA's Radiant Basics online course; I have also read many of Carol Fey's and Dan's books and have "lurked" on the "The Wall" for a few years now. I am willing to make the effort for education and training- I am looking for advice on how others have done so- in particular with wiring and controls. At times, the knowledge required of wiring, controls and design can seem overwhelming. I also plan on attending Dan's Classic Hydronics seminar this month and the I=B=R seminar in a few months.
  • Ken_40
    Ken_40 Member Posts: 1,310
    Jason,
    Unfortunately, the I=B=R classes just barely scratch the surface of wiring, 'stats and controls.
    Learning how to use a multimeter - all of it, including mA, continity, uA, ohms and of course the obvious one's: AC and DC-volts, is essential. Start off with a 20-dollar "wonder" meter and see if later on you need rectification readings like on large flame rectification burner controls, both Honeywell and/or Fireye.
    You are obviously mechanically inclined. Translating the "visual clues" of mechanics into trusting what your meter says - is how to think about electricity. it IS mechanical, as long as you know how to read the meter! The meter's setup and dial are the map needed to find out where the electrons are, and what level their doing whatever they're supposed to be doing - or not doing.
    Basic 'E' is something hard to glean from a book. It is hand-on lab dependent IMO. There are tons of basic 'E' books out there. None really all that good. Either so basic as to be childish, or so exotic as to be more confusing than helpful.
    Unfortunately, the electronics on simple gas trains is one thing. The electronics of oil-trains quite another. When you get into larger, more complicated systems, it is yet different again!
    Timie McElwain is among the best resources on the planet for gas stuff. George Lanthier the best on oil stuff. Both have all the know-how possible for the larger systems out there.
    Perhaps they can help? I'll e-mail them both now.
    If a book on-point exists, they'll know about it!
  • Ken D.
    Ken D. Member Posts: 836
    Wiring
    Depending on your experience, a good basic electricity course like the RSES will go a long way. The RSES also has monthly free seminars that are very helpful. For advanced training, courses like Tekmar and Honeywell are well worth it.
  • Jason what is your
    location? I have a training center in Rhode Island called Gas Training Institute. I cover everything you need to increase your wiring and troubleshooting skills.
    I have a series of 25 manuals listed here.
    Service Manuals Catalog
    * Denotes Manual used in Seminars
    *1. Fundamentals of Gas Vol I (New in 2004)
    Fuel Gases Natural Gas Facts
    Combustion Gas Burners
    Gas Pilot Assembly Gas Orifices
    Gas Pressures Mechanical Controls
    Burner Problems Gas Pipe Sizing
    Measuring Input
    Carbon Monoxide
    Air for Combustion
    * 2. Fundamentals of Gas Vol II (New in 2004)
    Air for Combustion and Ventilation
    Introduction to Venting
    Venting Requirements, Specifications, Design
    & Construction
    Conventional Venting Systems
    Masonry, Metal and Factory Built Chimneys
    Gas Vents, Selkirk Metalbestos Handbook
    Single Wall Pipe, Through the Wall Vent
    Termination,
    Vent Connectors, Vent Dampers and Tables from
    NFPA 54/ANSI Z223.1 National Fuel Gas Code
    3. Foreign Odor Complaint
    Training on procedures for
    investigating odor complaints, Gas Safety
    4. Gas Ranges
    Fundamentals of gas ranges - does
    not include electric ignition ranges
    5. Water Heaters
    Fundamentals of storage type water heaters
    6. Electric Ignition Ranges
    All the different systems used
    on Electric Ignition ranges
    7. Basic Electricity
    Electricity as it applies to gas equipment
    *8. Circuitry and Troubleshooting
    Volume I
    (New in 2006)
    APPLIED ELECTRICITY FOR GAS APPLIANCES
    PARTS OF AN ELECTRICAL CIRCUIT
    ELECTRICAL TERMS
    ELECTRICAL RELATIONSHIPS
    CIRCUIT COMPONENTS AND SYMBOLS
    ELECTRICAL CIRCUITS AND DIAGRAMS
    CONTROL CENTERS
    TEST EQUIPMENT
    COMPLETED WIRING DIAGRAMS OF HEATING SYSTEMS
    *8A. Circuitry and Troubleshooting Volume II
    THERMAL ELECTRICITY AND ELECTROMAGNETISM
    THERMOSTATS, GAS VALVES, TRANSFORMERS
    9. Kitchen Heater/Space Heater
    Includes all conventional Kitchen and
    Space Heaters in addition to unvented,
    Dynavent, unit heaters and floor furnaces
    10. Advanced Electricity
    Transformers, relays, multimeters,
    capacitors, solid state and electronic
    flame safeguard
    11. Fundamentals of House Heating
    Principles of heating, thermostats,
    settings, transformers, gas valves and pilots.
    12. House Heating Systems
    Steam and Warm Air systems,
    Wiring Diagrams different systems
    13. House Heating Systems
    Forced Hot Water, wiring diagrams,
    Zone Valves, Series Systems, Powerpile
    Systems, Gas Actuated, Motors/Circulators
    *14. Hydronics
    Introduction
    Aquastats
    Relays
    Switching Relays
    Aquastat Relays
    Transformers
    Electric Ignition System
    Zone Valves
    Troubleshooting
    *15. Powerpile Systems
    *16. Electric Ignition Systems
    *17. Advanced Electric
    Ignition Systems
    *18. Conversion Burners/Combustion Testing
    Includes installation, troubleshooting
    and combustion efficiency testing
    *19. Combustion Testing Designed Gas
    Equipment Volume I (New in 2006)
    *19A. Combustion Testing Designed Gas
    Equipment Volume II (New in 2006)
    *19B. Combustion Test Equipment
    (New in 2006)
    *20. Air For Combustion
    Carbon Monoxide
    Heat Exchangers
    *21. SmartValve™
    Same information as in
    the Advanced Electric
    Ignition Systems on SmartValve™
    Generation I, II and III
    *22. Multi-Zone Panels
    23. Troubleshooting Gas Electric
    Ignition Systems
    70 pages of excellent troubleshooting
    procedures a must for every technicians truck
    INCLUDES
    Intermittent Pilot Systems
    24 volt EI system on Burnham Boiler
    Hot Surface Ignition systems
    Integrated Controls
    24. Integrated Boiler Controls Manual
    The GAS Integrated Boiler Controls Manual is comprised
    of procedures for troubleshooting and determining correct
    operation of Gas Boiler Systems using such controls.
    It is a combination of:
    OPERATING SEQUENCES
    WIRING DIAGRAMS
    QUICK CHECK METHODS
    CONTROL SPECIFICATION SHEETS
    MANUFACTURERS INSTRUCTIONS
    25. Integrated Furnace Controls Manual
    The Integrated Furnace Controls Manual contains procedures on a number of different IFC’s being used on a number of Gas High Efficiency Warm Air Furnaces today. It has procedures for troubleshooting and determining correct operation of systems using such controls.
    OPERATING SEQUENCES
    WIRING DIAGRAMS
    QUICK CHECK METHODS
    I also have a series of 62 different Troubleshooting Guides.
  • mikea23
    mikea23 Member Posts: 224
    Wirsbo
    Wirsbo camps are great and the people there are top notch I found with wiring If you compleatly understand the system and what you want it to do. the wires are simple but looks harder then it is.
  • Jason Quinn
    Thank You
    Thanks to everyone for their input. Once again "the wall" comes thru. I'm really glad I asked. You have made some excellent recommendations- ones that I never would have thought of on my own. Tim, I have received your course schedules in the past and am definately planning on attending; also considering starting out with a manual. Please e-mail me a price list for the manuals. I am on your e-mail list. Thanks again to everyone for taking the time to share.
  • Shane_2
    Shane_2 Member Posts: 200
    I am a plumber also learning hydronics, I thought I was quite an expert till I started coming to the wall a year or two ago. I continue to learn everything I can. I will look forward to meeting you in Piscatatway(sp?).
    Shane F.
  • allenleo
    allenleo Member Posts: 26
    message to tim
    tim, how far out of boston is the school ? how long is the drive from boston ? how long is the course ? do you have all classes available at night ? what nights, if any, do the classes fall on ? does the course cover all the material listed in the 25 manuals you listed ? what is the cost of the course ?
    hope to hear from you, thanks.
  • I will send you
    an e-mail response to some of your questions.
    As to distance from Boston it is less than 1 hour. We are located in Warren RI.
