Solar Panel's and Cost???
scott markle_2
scott markle_2 Member Posts: 611
from what I remember 30 deg. from true south orientation is about as far as you want to go, after this and there is steep drop in absorption.
I can imagine straddling the peek with a narrow 8 tube collector (like the one hr recently installed) this would require some custom work for the support structure but would achieve desired (required) southern orientation. I don't think east /west orientation would have much economic value (R.O.I.)
From what I understand one aspect of evacuated tubes is that some correction for off axis can be made by slight rotation of the tubes towards south.
  • Empire_2
    Empire_2 Member Posts: 2,340
    East west exposure...:-)
    I would like to utilize the east west peaks that are roughly 35'x15' and get a lot of sun. What am I looking at as far as cost, new technology that's available and overall potential power output......
    Thanks
    Mike T.
    hot_rod Member Posts: 26,584
    Thermal solar or PV?
    For solar thermal panels Resol and a few others sell differential solar controllers with an extra sensor to "watch' panels on two different exposures. I know Oventrop has that control available.
    hot rod
