Are these quotes reasonable?
Rich Kontny_4
Member Posts: 73
Get three quotes in order to compare. Make sure all bids are using similar materials and equipment.
Rich K.
Rich K.
I want to add an indirect hot water heater to my existing boiler, and also add outdoor reset controls at the same time. I've gotten two quotes, and both seem higher than I was expecting.
Quote 1: Install 80 gallon SuperStor indirect and Taco zone controls and outdoor reset. $5600 total.
Quote 2: Install Weil McLain Plus 80 indirect - $4700. Install Tekmar 260 outdoor reset controls - $1600. Total cost $6300.
Should I keep looking?0 -
we dont get into pricing
on this forum..we don't know the complexities of your particular system, nor do we know the ''cost of doing business'' numbers of the companies involved.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
Sounds like...
about about one day's work for a competent technician. If they charged the going rate, which seems to be (very dependent of locale) between $75 and $200/hr., the labor alone could run between $600 & 1,600. Add to that, materials at ~ $1,500 with a reasonable markup on parts of 1/3, plus taxes and you get something between $2,600 and $3,600. Then too, zone valves, copper, fittings, gas, solder, wire etc. adds perhaps another $200-400.
Both designs/options are in the "better solutions" category (I like both ways and brands equally), so without seeing the job - WHICH IS ALWAYS CRITICAL TO PRICING ACCURATELY - it is nearly impossible to assume anything that would be "on-point" in your case.
Should a lead man and a helper both - be required, (and in all fairness, how's a man going to jerk a 300 lb indirect down the stairs without help going to manage...
The quotes are not that far away from reasonable. I'd get one more quoute and see what happens.
This article I wrote some years ago about how to find a good contractor may help as well:
http://www.masterplumbers.com/plumbviews/2004/good_contractors.asp
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
