thermal expasion of air
j.osborne
Member Posts: 2
how can i calculate the pressure change of air based on temperature change?
i have 1 cu ft of air at 15 psi and the temperature raises 100 degrees f. what is my end resulting air pressure psi?
PV=nRT
PV=nRT0 -
Because air behaves as an ideal gas you can use a simple equation:
P1 * V1 / T1 = P2 * V2 / T2
P = pressure
V = volume
T = temperature
Have messed this up. Pressure, volume and temp must be kept on the same relative scale.
You must use absolute temps in the gas equations. The 70 deg F = 460+70 =530 R and the 170 F is 630 R. Also the pressures must also be absolute, psia not psig.
psia= psig +14.70 -
Thank you. Made it even worse and removed the calculations. Sorry.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
