OSV
steve_29
steve_29 Member Posts: 185
Thanks John that seems like the animal I'm looking for.
  • steve_29
    Need some advice here...
    I have an outside tank feeding a furnace located in a basement.
    Top feed to furnace... approximately 12' above pump.
    What can I use to keep the tank from syphoning, an OSV can't be used because it's over 3' above the pump?
    Any ideas?
  • clammy
    clammy Member Posts: 3,242
    tiger loop
    If this is a one pipe sysytem use a tiger loop and convert your burner pump to a 2 pipe system and if you want install a osv on the supply line feeding you tiger loop > I myself have always been a fan of pre /post burner realys with a oil solinoid valve on the jet line this set up usually helps reduces your pump vacume and over all reduces any flame varations assocated with the pumps producing vacume ,it's a nice set up it also reduces the amount of oil that you are circulating back to your tank unlike a traditional 2 pipe system which will reduce how quickly your filter gets dirty i'll try tp post a pic peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • John@Reliable_14
    John@Reliable_14 Member Posts: 171
    I would check out an.................
    Preferred Utilities anti-siphon valve.
  • steve_29
    Clammy I just saw a setup almost like that, it didn't use the tiger loop though.
    thanks for your suggestion
