Hydronic Heating and Cooling Manual
mewondo
Member Posts: 1
I am searching for a manual that covers industrial hydronic heating and cooling. Do you have any recommendations?
Define \"Industrial\"
if you would.
If a general text of hydronic heating in general is desired, you could check out John Siegenthaler's "Modern Hydronic Heating (Second Edition)" which to me is a definitive text on the heating, hydronic and controls side for any residential and light commercial projects. The principles are the same, scaled up.
For cooling, Eugene Silberstein has written, I believe, several texts. All of the above are available via the "Online Store" tab above on this site.
For industrial design per se, Trane has an excellent textbook ("The Blue Book") which covers cooling for some decent sized projects.
Also, when you say "covers" the subject, do you mean from a design, maintenence or repair point of view or just an overview to understanding? Huge differences."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
ASHRAE Handbooks
Lots of useful info in the ASHRAE handbooks. They are usually my first stop when I am looking for answers.
Tim D.0 -
Another good one
I've not found a great "all in one" Load up on as many as you can afford.
hot rod
- 167 Indoor-Air Quality
