Thermo-Dynamics S100
Big Ed_3
Member Posts: 170
We all have .. . Clean good hot fire is the key for that boiler . Crushed tube , flat baffles with bumps that collect sulfur deposits.....The S 100 right ? First off what type burner you are using ? And what numbers do you run it at ? The more you can give us the better we can help you ...
ThermoDynamics S100
Over the past couple weeks, I've had nothing but bad results with a Thermo-Dynamics S100 boiler sooting up. I was wondering if anyone else has run into this problem and could offer up any advice/solutions.
Thanks in advance,
Paul0 -
what have ...
you done?
- 167 Indoor-Air Quality
