Zone valves and flow meters
Josh M.
Member Posts: 359
Not really sure what options you are looking for on the zone valves. Could you elaborate a little more?
As for the visual flow meter and balancing valve Bell & Gossett has a combo unit that works great. Here is a link: http://www.bellgossett.com/productPages/parts-BG-Thermoflo-Balancer.asp
Josh
Josh
Zone valves & flow meters
I'm thinking about starting to use more zone valves and fewer pumps.Looking for options.Also does anyone make a visual flow meter to work in conjunction with a balancing valve.
Thanks,Dobber0
