where to buy brass air bleed for hot water radiator
Weezbo
Member Posts: 6,231
if so, you wont be able to find any....nobody uses them there:)
most plumbing companies have them in the van or truck.:)
Air bleed valve
Hi, where can I buy 1/4" brass air bleed valve for water radiators
thanks
Kevin0 -
Air bleed valve
thanks
Kevin0 -
The ONLY bleed valves I've been able to find for hot water radiators are these.
While the base metal is brass they're chrome plated. A good hardware store or plumbing supply house should have the bleeders and keys individually--but they're all identical.
Other styles are available in Europe (particularly the UK) but I'm fairly certain that diameter and/or threading are different.
If you find a US source for another style, please share!
- 120 Geothermal
