Infrared Thermometers w/laser pointers
Daniel_3
Daniel_3 Member Posts: 543
Try harborfreight.com
if you are looking to save a buck or two.
  • BAB
    BAB Member Posts: 118
    Infrared Thermometers with laser pointers
    There do you get Infrared Thermometers with laser pointers. I am looking for a source of supply, ... who sells them? I have a lot of steam traps that I want to monitor/check for insert replacement. Am told that the barehand touching a trap dischage pipe is not the best way of judging a good vs bad trap. Traps are typically Barnes & Jones #122 & # 134. Bromley
  • jim lockard
    jim lockard Member Posts: 1,059
    Infrared T-meter
    Mine is a Yellow jacket made by Ritchie Model #69235. I purchased it at R.E. Michels Co. Any good HVAC supply house should sell them, Field piece makes one as well. Best Wishes J.Lockard
  • ALH_4
    ALH_4 Member Posts: 1,790
    Fluke/Raytek
    Grainger sells them
  • Steverino
    Steverino Member Posts: 140
    FERGUSON
  • Steverino
    Ferguson
    Try Ferguson for the UEI Scout:
    http://www.ueitest.com/product-inf155.html
  • Ed_26
    Ed_26 Member Posts: 284
    infra-red thermometer
    The thing you need to watch is the 'spot to distance ratio'. If you are taking measurements from 20 - 50 ft. You need one with a good ratio to be accurate. (accuracy = $$)
  • hr
    hr Member Posts: 6,106
    Ridgid also has a new model
    available. Also check out the offerings at Johnstone Supply.
    hot rod
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    I have
    A Fluke 62 Mini..around $100 or so from Grainger
  • Steverino
    ridgid
    > Johnstone Supply.
    > hot rod
    > _A
    > HREF="http://www.heatinghelp.com/getListed.cfm?id=
    > 144&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
  • Steverino
    ridgid
    the Ridgid is also available at Ferguson. Part number 23578, Ridgid #IR-100
    http://www.ridgid.com/Tools/IR100-Thermometer/index.htm
  • realolman
    realolman Member Posts: 513
    might not be
    the quality you're looking for, but sears has them... craftsman.
