heating a pole building
leakman
Member Posts: 4
Ihave a building 30x60 with 14' ceilings half of it the cement floor has been poured the other half is dirt. we are doing radiant on the dirt side but do not know what to heat the poured side with.The customer does not want a fan type heater, and we would like to utilize the boiler if possible.
If we did not use the boiler we were thinking gas radiant ceiling heaters. I need some help The Leak Master
how about....
some frestanding CI rads...you could find some that are used for a fair price...new would be $$$...kpc
pole bldg.
14' ceilings... how about ceiling radiant - water?0 -
pole bldg
You could use tubing in the walls or even forced air hot water units. Baseboard would get beat up I would think. I think I would put in infared tube on that side and infloor on the other. Make sure you insulate the floor first!!0
- 120 Geothermal
