Dwyer Smoke Pump
Darrell_7
Darrell_7 Member Posts: 35
Do any of you guys that test combustion know where I can get smoke paper for an older Dwyer Smoke Pumo? This is a rubber pump bulb with an acrylic block that holds the paper. The paperr looks to be about 1.5 inches square rather than the rolls that the piston pumps use. I was given a full Dwyer Kit and I'd like to use this part of it if I can along with my Trusty Testo.
