Recall news (Dan H.)
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,687
Please read <a href="http://uk.sys-con.com/node/811443"target="_blank">THIS</a>
Retired and loving it.
  • Noel Kelly_3
    Noel Kelly_3 Member Posts: 43
    Interesting aside...
    "When the recall program began in February 1998, Hart and Cooley Inc., the manufacturer of Ultravent pipes, agreed to participate in the recall indefinitely. In December 1999, Hart and Cooley Inc. was purchased by EQ Corp., of Norwalk, Conn., a subsidiary of Equilease Corp., and renamed Falcon HC Holding Corp. The firm currently known as Hart and Cooley Inc., now owned by Tomkins PLC, is not the subject of this press release.
    Despite having ample assets to continue funding Falcon HC Holding Corp.'s share of the recall, EQ Corp. has informed the Commission that it is not legally responsible and, therefore, will not do so."
    http://www.cpsc.gov/cpscpub/prerel/prhtml06/06022.html
    It is difficult enough to keep up with the recalls...but really....it is hard not to be cynical when you read this sort of doodoo!!!!!
