Formula to determine steam pressure at different heights
Brad White
Member Posts: 2,399
temperature at elevation? As a captive gas within a piping system the pressure within a given building at different heights is academically insignificant. Sort of like air pressure being 14.7 PSIA at sea level and about 12.2 PSIA at 5,000 feet.
It is not like water where the lower floors in a high rise zone will be much higher than at the top.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
Calculating steam pressure at different heights
Does anyone know the formula to determine the steam pressure at different heights?0
- 167 Indoor-Air Quality
