G115 Quietest Burner?
hot_h20
Member Posts: 1
Quietest is the Riello BF series - but requires outside air and can be touchy to tune with chimney configuration
Beckett NX produces an unusual hum that can sometimes be heard through inside plumbing (baseboard, DHW lines, etc).
Looking to install an oil-fired G115. Will be using boiler room intake and chimney exhaust. Want to know which is the quietest burner to use and any problems that may be associated with its use. Many thanks.0 -
Well I will tell you....
I have a 115 in my house. I have a Riello on it..its ok. I usually install Carlin ez-1 and think , that properly tuned they are quieter...especially with the intake boot....others will disagree. kpc
Actually Kevin Id agree both your choices are good ones. I also think folks will be pleasantly surprised with how quiet the New Beckett N/X is also.
Your friend in the industry,
Alan R. Mercurio
www.oiltechtalk.com
i have a riello on my g115 and love it quite as can be
good luck0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
