Steam for humidity
Boiler Guy
Boiler Guy Member Posts: 585
You post on system savings got me thinking. I had a customer ask if there was any way they could use the steam in the rad(s) to add some humidity to their suite. Would it be possibe to install a tee before the vent with a ball or needle valve to permite syeam to enter the suite? Thoughts?
    EBEBRATT-Ed Member Posts: 19,606
    I would think that the additional make-up water required would be bad for the system and cause unnecessary corrosion.
    ED
  • Fred Harwood
    Fred Harwood Member Posts: 261
    Humidity
    The makeup water quality becomes an issue. I'd recommend against it. Simple room humidifiers probably would be better.
  • Boiler Guy
    Water use
    I was thinking along the same lines too. How much water do you suspect bleeding one rad for humidity would use? Is there even a way to calculate it?
    The firetube boiler holds 770 USgal to normal water line
