honeywell stat
Empire_2
Member Posts: 2,340
They are nice stats, but do not do half of the things other stat's do. Although you may not find the status lights, the honeywell and Carrier Totaline has almost any stat to fit your application.
Mike T.
Mike T.
is there a direct replacement for the honeywell 7300 series,stats. seen one the other day subase has trouble lights on it .wired though the rooftop as shown on schematic using the x and the c terminal0 -
The TB series took the place of the T7300 series. You can look at all the options at http://customer.honeywell.com. When you get there, scroll to the very bottom right corner and enter tb in the blank white box. Then click on the arrow beside it. Up comes pdf's of the literature for all the models.0
- 117 Geothermal
