operating temp.
JHF
Member Posts: 3
I have a Mueller Climatrol model no. 10-S-W-9 steam boiler at home.
Works great. What is operating temperature?
Regards
Regards
Depends
On what your Pressure control is set at. Normally, a residential steamer will operate at 1PSI or less. This would equal temps of less than 220* if I'm not mistaken. The higher the pressure, the higher the temp will be.0
- 120 Geothermal
