WSHP and radiant
jp_2
Member Posts: 1,935
the thread:
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=286224&_#Message286224
Sketch?
I have been requested to do a water source heat pump to supply heat to a radiant floor system. I am in need of a diagram to verify how to hook up the system using a buffer/storage tank.
Customer probably will also want a hydronic air handler to supply cold air for the summers down here.
Can anyone help?
Thanks.
Bergy posted a nice schematic
here not too long ago. Close to perfect. ME and a few added some comments. See if you can search that thread.
hot rod
RE: Sketch for Radiant Heat Source
Jeff,
I found the following diagram from the folks at Houseneeds.com in VT helpful when I did the same: http://www.houseneeds.com/shop/heatingproducts/heatu/tankonezonemvmain.asp
Another place to look for more help here: http://www.houseneeds.com/shop/heatingproducts/heatu/heatinguniversity.asp?stype=../../../index.htm
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
