big radiators
Big Al_3
Member Posts: 1
I have a 15 section steam radiator approx 30" tall.
Its the only radiator that seems to have wet steam.
Would these big radiators sag over time?
I have a gorton D on it . Would I be better with two #6
Could it be condensing tooo fast?
Thanks from Big Al
Thanks from Big Al
big rad
try raising all 4 legs up 2 quarters at the valve end, and 4 at the vent end. the legs may have sunk into the floor, and thus altered the pitch of the supply underneath. check with a level as well.--nbc0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
