Bill from Honeywell
Boiler Guy
Member Posts: 585
why my local supplier cannot find any info for me. Do you have a part number I can use, please?
I am looking for 0-4lb open on rise.
Thanks
Thanks
Honeywell Controls
Bill I need some teck info on the T775E1015 temperature contol. Can you tell me how to calibrate the sensor temperature. Contols are working fine just the numbers are wrong.0 -
Hi, Wayne. Go to...
www.customer.honeywell.com and then scroll down to the lower right corner of the page. Click on "literature" and type the part number into the box. That will get you the complete tech data sheets on the product. No charge, and no password needed. You also can try the hotline at 1-800-468-1502, but since the T775 is a commercial product they may not have the answer.0 -
Bill is there any truth
to the rumor that the 0-4lb (I can't recall the Part No)vaporstat is no longer going to be available?0 -
aq475
Hi Bill i have a question about settings on the aq. My settings are 170 high 140 low & outside temp @ 0. i also have the supply sencer in the supply pipe with the temps around 45 should the boiler temp be around the min settings. mine seem to burn around 160. the avg. low is 20 f.
Thanks for your help i am out of ideals
scott0 -
Mercury...
BoilerGuy,
To the best of my knowledge, yes, there is aready a
replacement in the system, the "F" suffix part.
This has to do with a thing called "RoHS" or
"Restriction of Hazardous Substances", it's
an environmental thing that effects all
manufacturers,not just Honeywell.
HTH, Regards, db0 -
Sure, Here Tis'
BG,
The "F" series has been around for a while,
it appears "vaporstats" will be lost to history
unless someone comes up with an "ounces" solid
state switch?
HTH, Regards, db
L404F1651 .5 - 5#, Subtractive Diff, break on rise
http://customer.honeywell.com/honeywell/UI/Pages/Catalog/ProductCategory.aspx Catalog=Buildings&Category=L404F_12441&Product=L404A1651&ChannelID=%7b02CD9124-96F3-4A04-8EA7-1777CCCAD5B3%7d
Cross reference sheet;Mercury Free
http://customer.honeywell.com/Techlit/Pdf/63-0000s/63-9342.pdf0 -
Thanks Bill
Thank You I will look there.0 -
Thanks, DB...
That control is made by a different division of Honeywell, the Flame SafeGuard folks who make the controls for commercial boilers, mostly. I don't get product update info from them, so I really couldn't give you an answer. Try the website & phone number I mentioned above. Sorry for the lame answer!0
