Crown & Munchkin install!
Jamie_6
Jamie_6 Member Posts: 710
Here is a sweat little job that Nick finished up this fall! He divided up two apartments for a landlord. One the landlord pays the utilities the other the tenant does. Can you guess which is which?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • John McArthur_2
    John McArthur_2 Member Posts: 157
    Have you had good luck with the Crown boilers? I have serviced a couple but never installed one. Seemed pretty well built.
  • Dave_4
    Dave_4 Member Posts: 1,404
    Munchkin...
    I'd almost be tempted to have some bypasses between them. That Munchkin would save some money any periods where eiether no tenants were paying the bill or the tenants were out of heat for some reason. Just make sure the shutoffs are on the landlord's side.
    Nice and clean work on both!
  • Jeff Lawrence_25
    Jeff Lawrence_25 Member Posts: 746
    Combustion air
    Did y'all pull the combustion air down the chimney?
    One thing I did on a Munchkin was to get a 4100 box extension and give a bit more room for the cram packed wires.
  • installed these munchkins in a multifamily. only had room for one exhaust outside. used exausto to manifold intakes and exhaust
