Oil filters for dummies
Leo
Member Posts: 772
Those same kids who would play with the oil valve will play with switches and ball valves also. Techs who dislike the lever are just using that as an excuse.
Leo
Leo
This is a paper or felt filter not cartridge?
I'm trying to understand some of the equipment in the family house heating system. This Sid Harvey 264 replaced a Westwood F20 (50 micron); not sure if this sid harvey is 50 or 10 micron. Wouldn't want a 10 micron here since there since there's already one at burner. I'm not sure if the '264' name indicates the element or the holder name. On the cylinder it says it can work with the 264-1 or 264-36 elements.
Tech said next time they'll use a 'cartridge filter'; how is that different? I have heard that these days techs stay away from the felt filters...
Also not clear on what is considered the 'housing'--that's not the visible metal cannister, correct? Housing is what holds the paper or felt etc together inside the metal cannister? Supposedly cartridge is better since housing and paper/felt are changed rather than just paper/felt?
Thanks,
David
PS This is a Roth tank, and I can see why some techs have said that kids will end up playing with that suction assembly lever......0 -
264 is the size of filter. there is a larger one (265). Some wool filters can shed and clog smaller nozzles. Cartridge filters are similiar to automotive oil filter. They will catch much more then standard filters and cost a lot more. Since you have a newer tank, the 264 is a fine filter for you.0 -
David,
Sorry for the delay in my email response, I tried to reply a few times but it kept getting bounced back to me. Ill try to resend it again.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
