unions on gas lines
theprentice
Member Posts: 26
i'm just curious, I have seen numerous threads indicating that unions are illegal on gas lines. I asked my master plumber boss/employer, and he said that it would be near impossible to succesfully install a gas system without them. I know that on every boiler boiler, water heater, and appliance I have installed that is gas supplied i have used a union. I guess that I'm just confused, if someone could clarify I would appreciate it.
thanks.
thanks.
Key word...
CONCEALED union. In other words, you can not have a union mid pipe in a run that could eventually be covered by a sheetrock ceiling.
They are required at the appliance termination, except for the gas meter, where you are supposed to use a left right nipple/coupling on the house side of the meter. At least here in Denver, such is the case.
ME0 -
thanks mark,
that makes sense now, I am in Colorado as well (western slope) nice to know, I guess that you learn something everyday, that's why I love this trade0 -
the devils in the details:)
Mark,if you see a post on controling some circs with variable speed...got a min?0 -
You may be confusing
Dielectric Unions with a standard appplaince union.
Dielectric unions are used to seperate ferrous materials from non-ferrous, ie; Iron piping from copper. Many here disagree in thier use on a heating system. I don't use them, others do. They contane a rubber gasket that seperates to the two sides of the union to produce a barrier between dissimilar metals.
You are correct that a standard ground joint union is neccesary for all connections for gas applainces.
Scott
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
