Fastner for climate panels
swanmech
Member Posts: 69
Looking for rec. on fastner guns for installation of 1/2" Climate Panel onto existing concrete slab. Looking at Hilti GX100? or Paslode?. Would like to have appox. same speed & hassle free of our Senco auto screw gun.
Thanks
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=361&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Thanks
Dont do it.
Climate panels are not made to be fastened directly to a concrete floor. youll need to fasten a 3/4" plywood "subfloor" then fasten the climate panels to that. I have done dozens of jobs with them and have run into this problem, its just what you have to do unfortunately. And definately do not try to glue them haha, heat + glue = a mess and damaged finished floor. Also before you put the plywood down make sure a vapor barrier is installed.0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
