installing a blow down line for low water cut off
Mr. Rez
Member Posts: 1
Is the above subject line simply a minor repair?
Thanks for your time.
as always....
it depends...it is just the new line, the blow down (dirt pocket)valve or is it the rebuild of the whole unit....?
a picture would help
If you mean what I think you mean, it may be very simple. If you are not a professional, it may be more than you should attempt. Mad Dog
- 120 Geothermal
