on watch tool what is it
Ken Field
Member Posts: 123
We don't use ours often but it can be very helpful. It records oil line vacuum, pump pressure, safety control output, stack temp, and cad cell activity. It also monitors voltage to a power venter motor if the system is so equipped. When the burner locks out, you have a pretty good idea why. Even on an intermittent problem, it makes you look like less of a goof if you can't pinpoint it on the second call. That's when we usually will install it.
what is the on watch tool ??0 -
where can i buy 1 i'm looking for something of the sort --0 -
Bought mine direct
I know EK sells them but I believe you can get it direct if you want.
http://www.onwatchinc.com/model51/index.html0 -
how much was it ? there is no pricing on the site0
- 167 Indoor-Air Quality
