Weil Mclain pex-al-pex
Al Letellier_9
Member Posts: 929
Have a lot of this great tubing in my shop and want to use it up for small projects, but alas, no parts available from manufacturer. Anybody out there know who made the tubing and if anybody's manifolds and connectors work with it? I hate to see the stuff just sit there or have to throw it out. Manufacturer can't help (avoiding liability, understandably, but I would take the risk)
Thanks in advance.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Thanks in advance.
I am not 100% sure Al but I think Kitec is almost identicle in inside and outside Diameters. I know that my Kitec tools work just fine with the Weil-Mclain PAP. Worth looking into I spose.
pex al pex
call Jomar distributors in Watertown ma. they should have fittings you are looking for no is 800-560-6077 ask for steve cardirelli
Uponor...
Have opened one box of each already and the tag with the same inspector # came out of both boxes.... seems they are made in the place. Have used the Multicore tools and fittings with no problems.
Floyd0 -
Uponor or Viega
fittings work. I believe it was made by Unipipe, then Uponor bought them and shut down the Weil supply?
hot rod
Are you sure HR ?
We use Viega and when we did one job with W.M. it seemed quite different.
Certainly harder to work with.
Scott
pap tubing
Thanks for the help guys....I knew there was an answer and thankfully knew where to get it....can't beat the wall!!!!
- 167 Indoor-Air Quality
