Changing radiator need advice
ed wallace
ed wallace Member Posts: 1,612
I would just change out the nipple hopefully you have axcess to the fitting below the floor
  • eddie_8
    eddie_8 Member Posts: 1
    I am changing my one pipe steam radiator. the new radiator has taller legs and the connection is too short and has no more slack. do they sell taller on/off valves? or is better to add a nipple to extend it. pls help
  • ed_62
    ed_62 Member Posts: 4
    no access, any other suggestions?
  • frankiewrench
    frankiewrench Member Posts: 15
    I'VE DONE THIS
    Unfortunately the rad mfg changed the inlet connection height and created a nightmare for some folks. I've come across this more than once and I've used a sawzall to cut down the height of the legs of the rads. After the cut, use a file to remove the sharp edges. If necessary, a steel washer can take out the rock of the rad due to unequal cuts.
  • ed_62
    great idea, what blade did u use on your saw? did u have a hard time sawing it?
  • ed_62
    what are odds the legs are hollow? if i cut hollow legs, radiator becomes garbage.
  • bob young
    bob young Member Posts: 2,177
    drill a 1/8 " pilot hole first
  • ed_62
    ok after i drill and notice its hollow how can i seal that hole
