Taco VS VV circs
Weezbo
Member Posts: 6,231
from a vs vv 007 and bolting it on my 0010.
the other thought that i have is to ask a friend of mine to make one.
anyone remove and replace a circuit board for one?
what happens if a circuit board fries ? how does one go about getting the correct controller board replacement?
to "make do" until a replacement "shows", would the sanest thing be to use a pc 705-2 and "hard wire" it as an "independent" stand alone within a system?
They use two different capacitors. The 007 uses a 5muf capacitor, while the 0010 uses a 14 muf. Otherwise the boards are the same. The electrical box is also different for the VS circ. It's larger with the cutout for the removable sensor terminal strip.0
- 50 Industry Classes
