Heated Walls
ALH_4
Member Posts: 1,790
This <a href="http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=303374&_#"target="_blank">Old Thread</a> has a bunch of radiant wall and ceiling photos.
Heated Walls: I need some pics
Need some pics showing install with plates behind wall. I am doing install in my bathroom behind shower walls.
Thanks0 -
Heated walls
Do this all the time. Usually put the wall loop on a separate wall timer so you can turn in right before you get in the shower and not heat up the whole bathroom.
You can also use an x10 type switch so that it turns on and off a a preset time. For example, turn on a 5:50AM and off at 6:30AM - the time that you may get in the shower.
Take a furring strip mount on wall to use as a guide for the router.
Its great. I wish I did it in my house. I just looped the pex in the wall and used tekfoil in an attempt to reflect the heat energy into the wall. Plates are much better - they draw the heat off the pex and are in direct contact with the durarock, wonderboard, what ever your using.
Enjoy
Glenn0
- 167 Indoor-Air Quality
