Why we get work
Timco
Member Posts: 3,040
says the format is not valid....
Tim
Tim
Just a guy running some pipes.
Oh Boy
Sorry if this has already been posted. You need powerpoint to view it. You can download a free powerpoint viewer from Microsoft if you need it.0 -
I got it to open
I got it to open using my Power Point reader. Man, you sure can't make this stuff up. It would be hilarious if it was so sad.
Leo0 -
Great Stuff
What I'd like to know is how they went about collecting these gems.0 -
I get the feeling the guy that put this together is a home inspector.0 -
Paul
I downloaded powerpoint like you said, but I can`t get it to open,,,,me and computers,,sheeesh.
Dave0 -
File
I saved the file to my desktop - then I double-clicked on it and powerpoint reader opened it up.
HTH
Dave0 -
Tried that,
still no-go, sure wish I could see it, but oh well!,,,,,
Dave0 -
I have problems at work with these all the time, but they work at home. I have no idea why. Just another great Microsoft mystery.0 -
Ditto Paul
these "file extensions" always screw me-up big time!
Dave0 -
Dave... an almost simple solution
save it to your computer
rename the extension from .pps to .ppt and then try and open it0 -
my machine
was set to save it as "file type" (under the file name) as a " .cfm" file. in the file name call it home inspections.ppt (or whatever you want to call it). The important part is adding the " .ppt " at the end...your power point viewer should then be able to open it.
Mitch0 -
Thanks Uni,
I finally did get it to open with your directions, glad you were here!! Funny pics!
Dave0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
