Radiant Questions
Lil-Roc
Member Posts: 50
Uponor is Wirsbo... Uponor is the parent company of Wirsbo and they dropped the Wisbo name a couple years ago. Now they just use the Uponor name.
Radiant Questions
Good Morning All,
I am in the process of doping out an Ultra-Fin radiant floor addition to my kitchen.
As there are many types/brands of Pex to choose from, what tubing is the best/easiest to work with?
Also, what do you think of Shark-Bite fittings instead of crimp fittings?
Thanks in advance,Roland.....0 -
uponor and wirsbo both make good h-pex and p-a-p. I personally do not use shark-bite, although they are certainly rated for it. if i had no other choice, i would.
TimJust a guy running some pipes.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
