Water running thru radiator but cold???
Big Ed
Member Posts: 1,117
Did it work before ?
Water running thru radiator but cold????
I have Oil/hot water heat. Radiators run along the walls throughout the house. One of the radiators does not work. I bled the air out of the system numerous times. There is water running through the radiator but its cold. The piping is hot halfway to the radiator but then get cold. There is no valves or anything where the piping gets cold. Any suggestions anyone?...0 -
My guess would be the heat your feeling is gravity flow.
Theres alot of questions I could ask to try and get a sense of what kind of system piping you have, etc,..
I would call a pro there to check it out.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
