Galvanized pipe vs. cast iron ?
Brad White_9
Brad White_9 Member Posts: 2,440
It is not applicable to your one-pipe system.
A little galvanized pipe should do no harm, the only concern being sacrificial corrosion where zinc meets raw steel pipe. More academic. It should last for years especially if insulated.
  • huck_3
    huck_3 Member Posts: 6
    quick question,
    i just replaced a short run to a radiator on my one pipe system, with galvanized pipe.
    Is this bad? if so, just how bad is it?
    it's only about 3-4' of galvanized pipe.
    thanks!
  • Uni R_3
    Uni R_3 Member Posts: 299
    Are you using glycol?
  • huck_3
    i'm not sure...
    please give me a hint on what glycol is.
    whatever it is, i'm pretty sure i'm not using it.
  • Uni R_3
    My bad, my Brad
    Missed the "one-pipe" part...
  • Brad White_9
    In all fairness you could have been
    thinking "Mono-Flow"...
