oil burner
John@Reliable_14
Member Posts: 171
OIL BURNER
ive been working on a beckett rwb model cf500 oil burner had to replace oil pump old one was a 3 to 7 gph i had to use a 1 to 2 gph. burner is having delayed ignition and wont fire sometimes. will be able to get correct pump on monday will also call oil burner hot line to find out correct oil pressure and electrode settings.pump was bad but they also had someone there before me who could not get burner to fire and had adjusted all the setting elactrodes and air.does anyone know these settings for this model burner?or have any good tips on setting electrodes and pump settings?0 -
- 50 Industry Classes
