Weil McLain v Peerless Boilers
bcoate
Member Posts: 3
Need to replace my steam boiler. I have narrowed my quotes to two; one for a Weil McLain for $9000 and the other for a Peerless for $7000. Is the WM really worth the extra $2000?
peerless has METAL pushnipples
peerless is by far the superior boiler. weil- mclain is living on legend. rubber push nipples & their support staff is real shaky. never ordered a weil that a key component was not either missing or wrong. your downtime means nothing to them. peerless blows them away. and burnham is equal to peerless.0 -
Installation is Key
Either boiler will work if it is installed correctly. You could pay more for a less than perfect installation and that would be a shame.0 -
I Concur
I could not recommed a boiler that does not use push nipples to connect it's sections ....There was an error rendering this rich post.
or you could pay less and get what you paid for ---0 -
Peerless
Peerless is a good boiler. Very few problems with any Peerless boilers that I've installed. Good for steam & hot water. I'm not a big fan of elastomeric seals, especially for steam. There are going to be a lot of people chiming in on this one.0 -
had more problem with
Had more problem with boiler with steel rings than the rubber gaskets one. Never had problem with the rubber seals except when others decided to put in oil base boiler treatment and then blame it on the manufacture. Any boiler is a failure when installed wrong.0 -
Oil or Gas
You did not say what type fuel you are using. If you are using oil you would be better off with a Burnham MegaSteam boiler. Have you measured your EDR to make sure you have the correct size boiler. When you sign a contract make sure you include that the boiler is to be installed according to the manufacturers installation manual.0 -
Both are JUNK! Go with Burnham!
Seriously0 -
I would go as far ...
as calling them junk but the three pass design of the Megasteam does make it the best steam boiler on the market hands down!!0 -
Yes..
Burnham does have a good boiler, but given the choices from the original poster, I would pick Peerless. JMHO0 -
Fantasy land
NEVER had a problem with the Weil as far as the elastomer seals go. IF I need to call for customer support I've never had a problem either. Most who complain about Weil dont even use them. They've only heard rumors and go by what they hear. Push nipples rot out too! Peerless is a good unit as well (as far as steam is concerned). Neither are junk as steam boilers go. That said, I'd still go with the Mega Steam. In fact I'd insist. As Mr Mannino said, its all in the install anyway. Bashing any mfr. while hiding out behind phony email addresses is not the way to go here. Take those comments for what they're worth. NOTHING ! AND, Burnham is NOT equal to Peerless. The Mega steam has no equal.0 -
Simple Anwser
Would you like a boiler that is 87% AFUE or 81% AFUE for starters? I don't know what part of the country you are in but there are rebates out there for the 87%AFUE..I'd go with the Burnham Megasteam hands downThere was an error rendering this rich post.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
