P/S ladder piping
Robert O'Brien
Robert O'Brien Member Posts: 3,584
to your question.Do you do a heat loss? Your customers will benefit a lot more from a properly sized boiler than from P/S
  • Shawn_16
    Shawn_16 Member Posts: 1
    P/S ladder piping
    For replacement boilers, is it worth the cost,and what are the benefits of "Ladder" piping for a typical home.By typical, I mean a home anywhere between 1,200 to 3,000 sq. ft.,1 to 6 zones,closed loop,maybe a monoflo loop,maybe an indirect,maybe not.
    I install oil heat only,and in quoting jobs,when using a Buderus G215 w/ 2107 logmatic w/ outdoor reset, is there a benefit to the "Ladder" piping over standard S/R piping,especially when time,space and cost is an issue.
  • S Ebels_2
    S Ebels_2 Member Posts: 74
    Ladder piping?
    Are you referring to a two pipe primary/secondary system?
    Is there DHW involved?
