P/S ladder piping
Robert O'Brien
Member Posts: 3,568
to your question.Do you do a heat loss? Your customers will benefit a lot more from a properly sized boiler than from P/S
P/S ladder piping
For replacement boilers, is it worth the cost,and what are the benefits of "Ladder" piping for a typical home.By typical, I mean a home anywhere between 1,200 to 3,000 sq. ft.,1 to 6 zones,closed loop,maybe a monoflo loop,maybe an indirect,maybe not.
I install oil heat only,and in quoting jobs,when using a Buderus G215 w/ 2107 logmatic w/ outdoor reset, is there a benefit to the "Ladder" piping over standard S/R piping,especially when time,space and cost is an issue.0 -
Ladder piping?
Are you referring to a two pipe primary/secondary system?
Is there DHW involved?0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
