Powers pneumatic t-stat?
hvacfreak
Member Posts: 439
Powers is now Siemens , should look something like this one
http://www.sbt.siemens.com/sbttemplates/library/pdf/129116.pdf
Looking for a direct replacement for a Powers pneumatic t-stat. Was sold a Honeywell t-stat, but it has 3 barbs and wants rubber tubing. Powers stat has 2 copper pipes soldered to a connecting plate. Would love to just swap the t-stat and not convert.
TimJust a guy running some pipes.0 -
any numbers on the powers stat they make kits that will adapt to the plate0 -
National Energy..
National Energy, out of PA. They are awesome to deal with.
Website is neccdelivers.com
They handle a lot of pneumatics & I can almost bet they can find a replacement for you Powers thermostat. Good Luck!
Ross0 -
powers
another great person to deal with is PJ at industrial controls very smart man and i know he can help.they have many offices across the country.tell him tim from lc sent ya if you call. his number is 781-344-0140 that is the boston-stoughton ma number. hope this helps
tim in mass0 -
NECC
Ask for Chett, he is the man, sak him to send you a product catolog, he will be happy to do so,0 -
Try this...
The TP970A2038 is a universal replacement kit for direct acting applications. The barb fittings use plastic tubing, 5/32 or 1/4"; any system with copper is generally quite old. There are adapters. Go to www.customer.honeywell.com, type in the above part number in the "literature" box, and you will get a printable technical sheet. Pneumatics are available from commercial Honeywell distributors.0 -
I have some old powers t'stats. Post a picture and i'll see if I have one like it.0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
