Flo-Chek Operation and Placement
Big Ed
Member Posts: 1,117
If the flow valve is dirty or not sitting straight up and down it will by-pass. Zones with large supply piping, tall riser or a long enter run may need a second flow check on the return...
At least one flow valve per zone ,per loop....
Should the piping after a Flo-Chek that is on a two zone, two circulator sytem remain cold when the circulator for that zone is not operational? Is a Flo-Chek best placed on the return or the supply?0 -
BEST IS ON THE SUPPLY0
- 120 Geothermal
