Boiling out dissolved gasses ??
After a boiler skim or flush the fresh fill water needs to be brought up to 180-degrees to boil out dissolved gases right?
However does not just firing the boiler and running normally do the same thing or I missing something?
  • Big Ed_3
    Big Ed_3 Member Posts: 170
    Constant Fresh Water
    After a flush just let it run normally . What will cause damage is constant fresh water being added . Steam and condensation leaks will make a need for more fresh water . Also steam leaks will boil off the water and leave solids . During the non heating months , is good practice to boil the water before letting it sit during the summer .
