My first radiator install with pictures =)
the way things should be! BTW- What ever happened to your wall-rad project?<BR><BR>Dave
  • Daniel_3
    Daniel_3 Member Posts: 543
    The PO's had taken this rad out of the foyer to connect a rad in the newly finished attic. This created an issue with the heatloss in the foyer on cold winters when the door was opened. I plan to re-pipe the attic rad when s tee is installed around the same area on the main. It made a big difference in the foyer and all the way upstairs to have that rad back in it's home again. I could only feed the branch beginning with a 45 to avoid cutting into a joist and then I just used another 45 at the foundation. It works great!
  • Eric Johnson
    Eric Johnson Member Posts: 174
    Beautiful
    Beautiful radiator.
    I see you put it in before you finished painting the wall. That's the kind of thing I do.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Looks just like the old way. Nice job!
    A bit off topic, but that's an odd sub? floor. Looks like "beadboard" commonly used for porch ceilings, vertical wainscotting, etc.
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Nice...
    radiator finish. I like that glossy look. Paint or Powder coat?
  • Daniel_4
    Daniel_4 Member Posts: 5
    Rust-Oleum glossy white, one coat did the job. Of course there's a spot or two that need a touch more. I will find a place for those wall rads soon Jim. Won't forget what you did for me. . .
  • Daniel_4
    I'm doing a new boiler this summer and will tie in some new tees for two to three more branches for more rads and will find a place for them then. I am trying to be as patient as I can though =)
  • Daniel_4
    Yup . . .I am actually choosing anew color and well, the radiator was more important to me than color choice. I am so selfish sometimes . .
  • Daniel_4
    Tongue and groove pine was the mainstay for floors in my area in central MA in the 1920's. Most of the homes around here with hardwoods were installed in such a way. I couldn't tell you the size since I never measured but the sub floor and red oak on top together measure about 2 inches thick! Boy I love old homes!
