Pneumatic Steam Valve Help
larry_15
Member Posts: 55
Rick:
There are a couple of things you need to know before ordering a pnuematic steam valve.
(1) The valve type: you can find this out by the brass tag around the valve it will hhave a number like vg2231-um845v5220 This will tell you what the cv rating is.
Next would be theactuators head A3000-1 Thsi will give them the spring range pressure.
You can call Johnson Controls tech support at 800-524-1330 go through the menu for material support and they can help you order the correct replacemant valve.
larry
larry
Help me find this item
1-1/4" pneumatic steam angle thermostatic valve
Received many blank stares on this already. Would really appreciate help on this...
Thanks,
Rick
Johnson Controls?
They make lots of pneumatic valves.
jimThere was an error rendering this rich post.
statesupply.com
has a 1 1/4'' listed in their paper catalog..order #vp512a1783..don't know if its exactly what your looking for..its angle and pneumatic tho.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
I have used many Fisher valves for industrial steam applications www.emersonprocess.com/fisher/products/.0 -
Rick, check with Honeywell
New Info
Pneumatic steam angle radiator valve 1-1/4". Mounts on a cast iron radiator. Thanks again...
Rick0 -
Is this for replacement of existing valves? If so, are you utterly positive what you have cannot be re-built or re-conditioned?
Johnson Controls used to make them when they were known as "Johnson Electric". Once saw them in an old mansion. I could not find anything similar at their website, but it's a bit difficult to navigate. You might want to call them.
Otherwise I found angle valves in 1" and 1 1/2" but they were industrial controls and didn't look like they'd mount to a radiators. Found lots of 1 1/4" straight valves, but again industrial.
Only things I saw in the way of pneumatics at Danfoss were again industrial. They're such a huge company it might be worth a call to their North American office.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
