boiler problems
![[Deleted User]](https://secure.gravatar.com/avatar/84de8b4c38d16f6cd03561790e2a12ff/?default=https%3A%2F%2Fvanillicon.com%2F70a7d6087012bba4c9771779301f52a9_200.png&rating=g&size=200)
[Deleted User]
I have a tankless boiler that is about 30 years old. It was working fine yesterday I had oil delivered today and now the boiler is not firing and the temperature is dropping. Is this a fixable problem or am I going to have to replace my unit.
Cannot tell without more information
Have you had the service company come out and take a look? The delivery might have stirred up some crud especially if the tank was near bottom. Could be a clogged oil filter, loose ground, no power to the burner... any number of issues and no particular conclusion."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
