Pipe size's
Andy Byrnes
Member Posts: 42
Thank you for the English lesson. Do you any practical advice for the question I have stated or are you going to pop up and give me more free lessons as and when you feel I need them.
Literate plumber meet illiterate heating engineer.
Andy B
Andy B
Pipe size's
Can anyone give me the pipe size's used for piping up boiler,s in the US and Canada ?
I'm interested in hydronic boiler's and the pipe's used for the flow and return's to the boiler.
Also which is the most commonly used metal and fitting's used for running this pipe work ?
Thank's
Andy
it's wide open
The possibilities are almost endless.
John Siegenthaler's book gives an excellent thorough explanation of how things are done here now.0 -
I have seen on many installation's that installer's fit the spirovent. Now does this come with some kind of universal fitting so it can be fit to all installation type's. Or does the installer plan ahead, so if they are installing some thing like this they will adjust the pipe work accordingly ?
Or if an installtion is existing and some one want's to upgrade the system by installing a spirovent will consideration have to be made for the type of pipework used ?0 -
Spirovent
Generally the Spirovent is threaded NPT and can be adapted to the pipe type used.0 -
Is the fitting on the spirovent 3/4 internal tapered thread ? And do you find this the most useful for connecting to heating pipework.
Thanks
Andy B.0 -
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Well,
it's about time!
(Not directed at anyone but at alleviating my own ignorance.) As stated, one learns a lot here across a wide spectrum.0 -
Just read the site. You learn something new every day.
Andy0 -
Tsk tsk tsk....
People who live in glass house's shouldn't toss stone's...
And if you came here looking for perfect use of the English language, boy are YOU going to be disapointed...
These are HEATING guys, not ENGLISH majors... :-)
ME0 -
Next thing ya know is were going to be told a but crack isn't or isnt' or isnt a badge of honor.0 -
On some people
it is!"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
thank you, Mark
Thnk u Mark fur udderstding us heeting guys wuth eglush prublems....0 -
pipe's or i mean pipes
pipe sizes--- 1/4 " to 20 " , elbows ,tees & valves are your most popular fittings , sometimes ecccentric couplings ---now you are all set. don't worry about the apostrophes---- we don't even know what they are0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
