Steam System
BAB
Member Posts: 118
I had to wait 14 minutes for the answer to my question. I am impressed. Thanks a lot for the quick replies. Bromley
Steam Main Air Vents
A year or so ago (it could have been 3-5 years ago) I found on this website a chart, table, article comparing the various steam main air vents (Groton, etc.) with their respective venting rates listed as a result of actual testing. I can not find the data & would appreciate a nudge in the right direction. Email a reply if you know what I am asking about, ... thanks. Bromley0 -
Terry T
vent info
it is called "balancing steam systems using a venting capacity chart" available here. do a search using the button above and you will find where it can be purchased.--nbc0 -
Yeah...
That graveyard shift crew are a bunch of slackers, let me tell you. They hung around a full 14 minutes letting you sweat like that. It won't happen again.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
