Steam System
BAB
BAB Member Posts: 118
I had to wait 14 minutes for the answer to my question. I am impressed. Thanks a lot for the quick replies. Bromley
  • BAB
    Steam Main Air Vents
    A year or so ago (it could have been 3-5 years ago) I found on this website a chart, table, article comparing the various steam main air vents (Groton, etc.) with their respective venting rates listed as a result of actual testing. I can not find the data & would appreciate a nudge in the right direction. Email a reply if you know what I am asking about, ... thanks. Bromley
  • ttekushan_3
    ttekushan_3 Member Posts: 964
    Terry T
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    vent info
    it is called "balancing steam systems using a venting capacity chart" available here. do a search using the button above and you will find where it can be purchased.--nbc
  • Brad White_191
    Brad White_191 Member Posts: 252
    Yeah...
    That graveyard shift crew are a bunch of slackers, let me tell you. They hung around a full 14 minutes letting you sweat like that. It won't happen again. :)
