What's left to check?
don_185
don_185 Member Posts: 312
not enough static pressure to me.Your factory setting on your prv needs adjusting.Along with your bladder tank if you have one.
  • Michele_2
    Michele_2 Member Posts: 4
    Hi all:
    We're at our wits end here. Hot water gas boiler. No heat. Aquastat and Pump comes on when thermostat calls for heat. Burners fire up. Reaches high temp limit shortly after and then the Aquastat shuts down the burners. But the heat has not made it out of the basement up to the 2nd floor. The near boiler piping on the supply side gets hot but the heat doesn't seem to make it upstairs to the 3rd floor. Aquastat appears to work as it supposed to..on/off at high/low limit. So we changed the pump and bleed the radiators.
    Keep bleeding the radiators but still no heat. Are we missing something?
  • Mitch_4
    Mitch_4 Member Posts: 955
    sounds like
    a valve is off somewhere.
  • Darrell
    Darrell Member Posts: 303
    You might have a frozen heat pipe.
  • Mitch_4
    as you can see
    there are several possibilities. Did you do the work yourself? or a pro..it might be time to call in the pro if you haven't
  • Michele_2
    Thanks for helping. No doubt you're right you're right about a pro. Only pro that was recommended was booked up - couldn't come out for a week. Miserable with no heat so neighbour who's pretty handy tried to help us out with the pump. Radiator bleed seemed easy enough at the time so we did that ourselves.
