Wiring tstat with boiler
Paul_67
Member Posts: 3
I have a split level home with hot water heat set up for three zones (basement, living, upper) and the person before me appears to have all three thermostats wired together. This of course means that the bedrooms get warm and the living and basement are sometimes 5 degrees cooler. Really sucks when so cold out as it is right now. Do you have any wiring diagrams on what to do for a setup like I have. Right now all 3 thermostats splice together, go into boxes to control the pumps, then go to boxes and one wire comes out and goes to the boiler to turn on. I would like to have the three zones back again. Help!
Paul the easiest thing to do
is get a Taco SR503EXP Circulator control, diagram in the box and on the cover, straightens out the multibox mess and wires.
I second the suggestion. This box will make it so easy.0 -
Thanks. It does look like that is the way to go. Now I just have to wait until it is not 10 degrees below zero to do it.
Thanks again.0
- 50 Industry Classes
